JPNinPA
Active member
Nope! With the engine cool take the radiator cap off and jack the front of a jeep up, or park on a hill. Start the engine and watch for bubbles in the radiator. When it comes up to temp and the thermo opens there should be a number of bubbles comming out. When the bubbles stop after a min or so, top it off and put the cap on.Wouldn't it do this one it's own in the overflow reservoir?
The radiator cap is a 2 way valve it holds the system to 18 lbs before opening and allowing fluid into the overflow. Once the engine cools the valve opens allowing the fluid back in due to the vac effect of the system from the cooling. Water boils at 212 in a open environment but the boiling point rises when held under pressure, so by holding the system to 18 lbs the boiling point is raised. Lower the pressure and the boiling point lowers.Just a stab here. but I once had over heating problem and it turned out to be a bad radiator cap. To this day I dont understand that but I replaced the cap and no more over heating.
So if your cap is not functioning and opening at a lower temp, it is like having a lower lb cap. This allows the fluid to boil at a lower temp.
