gauges
Did they work and just stopped or have they never worked? check your fuses, there should be some under your dash and some under the hood.
If all your fuses are good , I think I would be takeing a look at the wireing harness to see if perhaps it had come unplugged somewhere.
What year Jeep?
If it is only the instrument cluster not working.I would start with making sure it was plugged in all the way.If it is you may have a bad cluster,or a serious electrical problem.
