Rough start
patrick78
Have a 97 TJ an it's taking it awhile to get it started. Any ideas on what I could do to fix, or what could b the problem? Thanks
Give a bit more dis description.
Does it crank at all?
Does it crank but not start?
starts but quickly dies?
Cranks slowly?
doesn't crank?
Try this. Turn the key to on( not to crank but almost) wait 3 sec then key off, key to on and wait 3 sec then off. Then on and start. I f starts right up it is the drain back valve in the fuel pump. You could continue to run like this or change it out.
if not post back.
