1. Steering stabilizer
    Trying to get some input on a steering stabilizer. Got a 84 cj with 35's and a 350 if that matters. Thanks for your time
    Re: Steering stabilizer
    Anything will do. A properly setup rig can run just fine without one, but they do serve well to make steering components last longer.
    Yea it does fine just thought it would make it tighter feeling
    Not that there is a lot of slop in it either.
    Feb 2012
    Cincinnati, Ohio
    1,993
    Yes it will help, espeacily with the 35,s. wont wonder as bad.
    Quote Originally Posted by 69jeepcj View Post
    Awesome! thanks guys for your advice
  7. #7
    It shouldn't wander any without a steering stabilizer. If it does, something is worn out or adjusted improperly.
  8. #8
    Quote Originally Posted by Bounty__Hunter View Post
    Well I it's mostly when I'm changing lanes not so much just cruising in the same lane and I never had 35's till now always ran 33's so maybe it's just me. But I'm going to go have it checked out and see if there is something wrong. But like you said ill still put one one to preserve parts as long as possible.
  9. #9
    Feb 2012
    Cincinnati, Ohio
    1,993
    A steering box brace will help too.
  10. #10
    Ok got a question about the wheel bearings. Driver side is bad. Need advice on how to do it correctly. So please input would be great.
  11. #11
    Quote Originally Posted by nthedeepstuff View Post
    This is what I got it to. It's pretty smooth. Or do I got to take more off? The bearing itself came out in one peace but the hardware were in shambles.
  12. #12
    <img src="http://www.jeepz.com/forum/attachment.php?attachmentid=16183"/>
    Take that back the inner bearing was gone
  13. #13
    Feb 2012
    Cincinnati, Ohio
    1,993
    any more progress?
  14. #14
    any more progress?
    Yep you were right it was my bearing nothing to do with a stabilizer putting everything back together today can't wait to get back on the trails
  15. #15
    Feb 2012
    Cincinnati, Ohio
    1,993
    Just so credit is given to the right person, I think it was bounty hunter that mentioned something else was wrong. glad you found it and got it fixed.
  16. #16
    Thanks bounty hunter got it fixed. And thanks to everyone who responded you guys are great
  17. #17
    Glad you caught it before it got even worse. Did you service the other side as well?
  18. #18
    I did figured if doing one side might as well do both.
  1. Steering stabilizer as trac-bar
    By joejeepny in forum Wrangler and CJ
    Last Post: 01-20-2004, 12:09 AM
  2. Steering Stabilizer Question
    By Robert_Strausberg in forum Wrangler and CJ
    Last Post: 09-24-2003, 09:47 PM
  3. steering stabilizer
    By jsharifi in forum Wrangler and CJ
  4. steering stabilizer
    By Bounty__Hunter in forum Wrangler and CJ
  5. Steering Stabilizers
    By Craig in forum Wrangler and CJ
