question about front end
clemtiger8
I have a 97 and a 99 tj 4.0. Im have to replace both front ends. Can i use cherokee front ends? If so, what year Cherokee? Thanks for advice.
Yes the high pinion dana 30 is a good swap...
Cherokees pre 2000? (Pretty sure...)
Sent from my Samsung Galaxy S3 using Jeepz
I believe 93 - 99 were high pinion and non center axle disconnects (same as your XJ but not your TJ) but should bolt right in both. Just make sure the new axle has the same gear ratio as the one it's replacing.
Reread your post and realized you have only TJs but it still applies.
