    1974 Points Ignition to 1985 Electronic Ignition - Help
    My son and I swapped out the old tired points driven AMC 304 & Installed a AMC 360 with electronic ignition.
    Our plan is to hook up the wires (we marked locations etc) and then see what we need to do to incorporate the ECM Dist into the system-tap the ECM into the '74's system.
    Anyone have an idea or a diagram whereas we can tap in the distributor to the Jeeps system so we can run this thing.
    Thanks,
    Jim
    Here is the build/swap - Jr's '74 CJ5 (304v, Another Project Soon To Start.
    '48 CJ2a 171231; '65 CJ5 Navy; '74 CJ5; '80 CJ7; '84 CJ8; '86 CJ7
    The electronic ignition module (red) positive feeds on the ignition power and the black to ground. The other plug goes to the distributor.
  1. electronic ignition
    By flatie46 in forum Wrangler and CJ
    Last Post: 05-28-2011, 11:24 AM
  2. 258 electronic ignition
    By 54cj3b in forum Items for Sale, Trade, or Give Away
    Last Post: 04-08-2011, 10:24 AM
  3. 87 yj Electronic Ignition Control Unit Where is it at
    By jdavidson in forum Wrangler and CJ
    Last Post: 06-07-2009, 04:44 AM
  4. Few problems after the trip to Vegas, need some help
    By laneiac in forum Wrangler and CJ
    Last Post: 03-31-2004, 03:23 AM
  5. 1985 cj7 tub HELP!!!
    By gizmo in forum Wrangler and CJ
