1. 4 wheel drive shifter keeps jumping out of gear. 1997 TJ.
    I have had problems with my 1997 TJ jumping out of gear when in 4 wheel drive. I just bought it and it has a 2 inch body lift.
    Aug 2011
    Springboro, Ohio
    1,869
    I had that trouble first time ever on the trail. Some nice man climbed under me, twisted a nut, and I was good to go.
    Do you know what he adjusted?
    Re: 4 wheel drive shifter keeps jumping out of gear. 1997 TJ.
    The main reason it jumps is the transfercase shifter is connected to the jeeps body and the Tcase is connected to the frame. With enough flex it jumps out of gear. Adjusting helps, but to solve the problem is to look for a T-case shifter relocation unit. Tera flex, advanced adapters JK and many more MFG's make these.
    blatant jokessubliminal sarcasmsexual innuendo
    Thank you I will look into the relocation kit. At first I thought I was hitting it with my leg but then realized that was not the case. I am up here in Wyoming and you know what it's like here.
    make sure the rubber shifter boot isn't "pushing" it out of gear too.
    '87 Comanche 4x4 lifted 5 1/2" on 33" tires 4.0L/AW4/NP242 $3500
    Perfect combination but too small to haul my Grand Kids and wife in.
  7. #7
    Aug 2011
    Springboro, Ohio
    1,869
    Quote Originally Posted by skipcrawford View Post
    Utah had my prob exactly. Not enough length for my 4" lift. A buddy made a longer mount for me later.
    Attached Thumbnails Attached Thumbnails 4 wheel drive shifter keeps jumping out of gear. 1997 TJ.-image-1564716855.jpg
  8. #8
    Aug 2011
    Springboro, Ohio
    1,869
  9. #9
    Thank you. This is my first Jeep and it's been fun other then it jumping out of gear.
  1. Jumping out of gear
    By medic06 in forum Wrangler and CJ
    Last Post: 11-06-2012, 02:12 AM
  2. T18 Transmission jumps out of 4th gear
    By ky76cj in forum Wrangler and CJ
    Last Post: 10-09-2012, 07:27 AM
  3. Jumping out of 2nd Gear
    By rserpas in forum Wrangler and CJ
    Last Post: 06-14-2009, 01:24 AM
  4. how can you keep water out of your differentials?
    By Sacredgroove in forum General Chat
    Last Post: 11-09-2003, 09:24 PM
  5. Low Gear 4 wheel Drive shakes when letting out clutch
    By jeepwanabe in forum Wrangler and CJ
