car cranks but wont start
tobs
Hey guys,
first of all I know that thing with the "engine cranks but wont start" is a common issue with those jeeps, I read a lot about it but it seems like I cant work that out myself...
if got a jeep Cherokee xj 1996 4ltr auto.
a few days ago I serviced my transmission. after doing that my car didn't want to start. the car cranked over but i had had no spark and fuel pump didn't want to gauge either. I got it started after i did the ignition dance (50 times on off to reset the computer).
my check engine light came on and stayed on. i checked for codes without a scanner but nothing serious came up, just code 12.
I drove around for a week with no issues at all, till i decided to get rid of that check engine light by detaching the negative battery cable what didn't work. so I did the ignition dance again cause i thought that would do it's job, but it didn't. i started the car normally, went home turned the car off, five min later tried starting the car, same problem again.. it cranks but no spark & fuel pump doesn't gauge.
after checking different sensors, fuses, plugs etc and not able to find one helpful faulty bit, i decided to swap my computer. the car started straight away just that the engine turned back off after 2-3 seconds.
so now I'm totally stuck, any helpful advice would be greatly appreciated guys!!
Hey Toby , sorry to see you got jeep trouble so close to the holidays . But trouble never takes the day off . If I read your post right , this all began after the trans service ? No trouble at all before ? Strange , I know . I'd have to say this is an electrical problem . You swapped the PCM and the engine stalled seconds after. Sounds like your going to have to start with the basics , no matter how boring that will be . But it seems that something will be overlooked if we don't look for everything and starting right from the battery . You definately want to check every ground from the battery negative cable and engine ground to chassis or firewall as it is possible the PCM is not getting a good ground . Also , we need to be sure that the positive cable is feeding cleanly the PDC and that the ignition switch is receiving battery voltage . I've said this so many times , on and off this forum , but you've got to diagnose any computer circuit with a computer safe test light and computer safe DMM when looking for voltage and continuity . Always disconnect the PCM harness when performing a continuity check of any circuit that will lead to or from the PCM. You can read voltage and check for ground with PCM circuitry but never send voltage to a PCM with an ohm meter. When wiring is declared good continuity wise , then you may reconnect PCM and look for voltage readings and grounds . Before trying to crank this engine in an attempt to start it again , you will need to do the checking first . It is harmful as you know to the starter and the engine cranking excessive . Overheats starter and engine cylinder walls don't get lubed due to low to no oil pressure. That would go for all engine parts .
You said your not getting any trouble codes with either PCM installed ? This sounds like power is lost intermittently . But I keep focusing on one thought , transmission service . The down stream O2 sensor would set a code but your not even getting that . That's near by in your trans service , but not saying is related . Just an item to check and not over look .
Just to let you know , fuse F15 in the PDC is tied in with the trans controller , fuel pump relay and auto shutdown relay . Look for voltage there when cranking . Don't know if your getting spark , but it sounds like your not getting fuel and you posted the fuel pump is not going on when cranking ? In general , you want to be sure that fuses and relays pertains to ignition and fuel pump relay are fed and voltage is moving passed to coil and fuel pump . Not saying the trans controller is the problem but this circuit is tied in at fuse F 15 . Primarily , look for spark and look for reading at the injector harness . Fuel pump relay must register while cranking on all terminals . If spark is found while cranking , then fuel pump circuit must be concentrated on and injector harness reading checked while cranking if injectors are firing . Remember , use a computer safe test light . Do not use a regular 12V test light on computer circuits . Measure voltage with a 10 mega ohm impedance DMM as well . Most good meters today are rated computer safe but be certain as you don't want to jeopardize the PCM and just make more problems .
Hope this helps . I have a wiring diagram for '92 jeeps if needed . Greg
A quick question, when you swapped your PCM, did you get it set to your VIN number? Your keys have a chip in them, your PCM needs to be flashed for the vin# which is set to the keys transponder #. The start up...run a few seconds is exactly what happens when you run an uncoded key without a transponder chip.
No I did not get it reset and I don't think i got a chip in my key either I haven't even got a immobilizer
Similar problem where my Jeep will crank.. sounds like it keeps cranking as if I kept the key turned. But it wont start. happened months ago then went away. Now its happening regularly. Yesterday I got an "transmission overheat" message while trying to start it. Never seen that before. I let the car sit a few mins with the hood open. Then tried it again... started on the third crank. This morning started right up on a cold start. Wondering if it could be transmission sensor or maybe Starter wire?
2007 Grand Cherokee.
Or the crank position sensor. They go flaky then bad. When they do it results in no start condition.
Also search the error message. IIRC there is a direct cause. I'll post back here if I could find it.
