1. 1979 CJ5 I'm new at this
    I have a 1979 CJ5. The roll bar is starting to rust out where it connects to the body. Most jeep parts can be found on lots of websites. However I've noticed factory style roll bars are hard to find. Other then Ebay I haven't found much in the way of kits or DYI sets on the market. As for fully assembled bars I haven't found any. Am I just looking in the wrong place?
    Thanks,
    ali
    What area do you live in? Do you want a OEM style and an aftermarket full cage style? I have a lot of contacts, may be able to point you in the right direction.
  3. Re: 1979 CJ5 I'm new at this
    a lot of early ones just mount to the flat rear area. I prefer the ones that mount to the floor .
    Feb 2012
    Cincinnati, Ohio
    1,993
    The ones that mount to the floor behind the front seats are on the 80,s models. I believe 81 and up.
    Quote Originally Posted by PoliceMonkey161 View Post
    I live in Michigan. Not to far from Grand Rapids.
    Thanks again
    The OEM roll bars are hard to find for 2 reasons, limited production and that the suck as roll bars and offer little to no protection. I understand if you want the stock appearence and I can appreciate that, but if safety is your concern, put in something far more substantial with solid A and B pillars that attach to the frame.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  7. #7
    Welcome.
    I agree that the OEM rollbars do more for looks than your safety. Check summit, jegs, racingjunk, and others for quality rollbar kits shipped to your door or a local speed shop or hotrod builder and have them make one for you.
    http://www.cardomain.com/ride/815022 long sold.. now its a 78 cj7, 304 auto at, AMC 20 and disco front d30. 4WD is only a drive shaft install away. What I'd do for a couple of wide d44s, d300..
  8. #8
    Quote Originally Posted by 69jeepcj View Post
    Actually part way through the 1978 model year the bar went from being mounted on top of the rear fender wells and bolted through the side of the tub to the main bar being mounted to the front of the rear fender well/floor behind the front seat. Also 1978 was the last model year that a rollbar was not required in a CJ by Federal standards with the bar being listed as optional equipment and until that time there was a thriving cottage industry throughout the country of small shops that offered rollbars.
    This might be of some help:
    http://www.jeep4x4center.com/jeep-cj5/roll-bar-cage.htm
  1. Brand new at this
    By mrhc in forum Wrangler and CJ
    Last Post: 07-28-2009, 08:28 AM
  2. New at this stuff
    By Dac25 in forum New Member Introductions
    Last Post: 02-20-2009, 06:54 PM
  3. Stupid Wrangler Question (I'm new at all this!)
    By TerryMason in forum General Chat
  4. Going to look at this YJ Today (Whaddya think?)
    By Tug-n-pull in forum Wrangler and CJ
  5. new to this, but can't download advertisements
    By Tug-n-pull in forum Forum related
