No start No power to ignition!
JohnBoy72
Ok so yesterday I drove my 91 yj 2.5 all day and it ran fine and drove fine . I got home and cutt it off and all the lights and pushed in the Ebrake. Next day I get in it to goto work and when I turned over the key nothing happend no power no clicking Nothing. I checked battery and it's good checked fuses and tryed swapping relays and still nothing . My headlights and radio work when I push headlight switch but no power to the ignition switch to start the vehicle. Anyone ever had this problem???
look into the ignition control module if a 91 has one. Did you actually check for power at the switch?
Park or neutral safety switch. Or clutch switch.
Besides checking power at ign also check the voltage while starting. Does the voltage drop to 9 or less when you turn the key?
Ok check all fuses and relays and just put a new battery in and still no power to ignition I'll try to test the switch tomorrow because I don't have a bolt meter at home .
