1. Replacing the timing chain in a 06 LJ
    I知 in the process of replacing the timing chain in a 2006 LJ with a 4.0.
    At this point I知 having trouble getting the automatic transmission cooling lines removed from the radiator.
    I致e tried the quick disconnect tools made for fuel lines but can稚 seem to get them off.
    Is there a special tool or a trick to this?
    Thanks so much,
    Jake
    American Legends Restoration
    Dec 1999
    Virginia Beach VA
    8,089
    Re: Replacing the timing chain in a 06 LJ
    I'm not sure if you got this squared away or not, but for those that come later, here's a link:
    http://www.jeepz.com/forum/all-other...tml#post216322 (How to remove transmission line to radiator)
    My 2005 Wrangler Build Thread
    滴e who is without oil shall throw the first rod. -Compressions 8.7:1
    Thanks Terry,
    Feb 2009
    Dayton Ohio Area
    5,864
    Curious as to why you are changing the timing chain? And if you are awre of the ODPA issue with 05-06 TJs that result in worn cam gears and timing issues?
    No I was not aware of the ODPA issue or what it means.
    I was in the process of replacing a rusty oil pan and noticed a lot of play in the timing chain.
    I'm just an old man that likes to play in the dirt.
    Feb 2009
    Dayton Ohio Area
    5,864
    Quote Originally Posted by gotdirt View Post
    No I was not aware of the ODPA issue or what it means. I was in the process of replacing a rusty oil pan and noticed a lot of play in the timing chain. I'm just an old man that likes to play in the dirt.
    Ok I thought of you were chasing a timing issue you might not have heard of the issue with 05-06 tj. Here is some info for reference if you or others need:
    http://www.jeepforum.com/forum/f9/20...topics/1144202
  7. #7
    There is a wealth of information in that fourm.
    Thanks so much,
    Jake
  1. Think it's time to replace the sub?
    By southtj in forum Jeep Electronics and Audio
    Last Post: 11-09-2010, 08:16 AM
  2. When do need to change the timing chain?
    By gotdirt in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-07-2010, 11:29 AM
  3. easiest way to the timing chain?
    By sweetpeet in forum Wrangler and CJ
    Last Post: 09-26-2009, 11:52 PM
  4. timing chain replacement
    By MikeB in forum Wrangler and CJ
    Last Post: 04-21-2006, 02:48 PM
  5. How hard to replace the rear seal in transfer case.
    By MudderChuck in forum Wrangler and CJ
