CJ gauges are dead
Donl
Is there a common fuse for all the gages? None of mine work, not even the warning lights, 1981 CJ7.
The fuse box on the driver side bulkhead should have fuse description. The gauges have a common ground.
Sent from my iPad using Jeepz
Our Jeep CJ's can be full of electrical gremlins, and not from just what the P.O. did.
CJ gauges are electrically grounded to the Speedometer housing by their physical contact, the Speedometer which in turn is grounded to the steel dashboard by contact, then to the body tub. Now IF it exists, a grounding strap from the negative battery terminal to the body tub is how the factory and many have addressed grounding issues. Further steel is not the best conductor of electricty. Some, myself included have gone the extra step of adding a negative bus bar and copper wiring to address further grounding issues. Over the years I've found a couple of excellent write ups about gauges and electrical in general that I commend to your reading;
Jeep CJ Gauge & Sender Diagnostics
Been reading the good book of JeepHammer! - JeepForum.com
