2001 TJ Rear wiring
Green Acres
Jeep TJ 2001 - Need help on wiring. Left brake and turn signal quit working - was flashing fast, backup and tail light work fine. replaced bulbs still did not work so replaced lighting module. That stopped the fast flashing but still no brake/turn signal. I pulled the lighting assembly off and the green wire was broke… thought that would be an easy fix but found a rats nest of wiring from previousowner installing wiring for towing it. I can’t find an easy wiring diagram orcolor codes to remove this mess. Any help appreciated.
Thanks again JPIN PA - found the entire manual this came from!!! - Now ALL turn/tail lights work,,,Left brake light does not - still piddling with wiring.
Just click on the pic to get full page view.
Check the ground at the light that is not working. If there was a trailer connection they may have cut the connection for the brake.
. Do you have trail guards over the rear signals?
I had 1 screw in on the light assembly when all but the brake light was working, FINALLY just screwed in all 3 and Voila!!! all worked!!!
Thanks again JP!! Hope I can return the favor some day :)
I had 1 screw in on the light assembly when all but the brake light was working, FINALLY just screwed in all 3 and Voila!!! all worked!!! Thanks again JP!! Hope I can return the favor some day :)
Clean the ground connection or you'll have this issue again.
