2005 TJ - looking for the right speakers for front and soundbar
stephdan
I have a 2005 Wrangler TJ. I want to replace the speakers in the dash and the soundbar. Any recommendation on the best speakers for TJ?
If you are not replacing the head unit is adding an amp, be sure the sensitivity is high. 87+. 92 + would be best.
I put in 6.5 4 way speakers in the sound pods on the rollbar. I also mounted 5.25" 4-way up front in place of the dash speakers. There is a mounting plate to convert to 5.25 made by a few places. You could easily make one out of wood. There are dimensions in some jeep forums.
There are proprietary connectors on the speakers in the sound bar. You'll want to order the connectors so that you don't have to cut the harness off. I cut the connectors off mine, and the wires are pretty short now - wish I had waited. I *think* these are the correct connectors: http://www.amazon.com/Metra-72-6514-Speaker-Chrysler-Vehicles/dp/B0007WTEVM/ref=sr_1_1?ie=UTF8&qid=1451789038&sr=8-1&keywords=jeep+speaker+adapter
Yes!
Crutchfield carries them as well.
