Thread: team rush
    team rush
    Does any know if the team rush ( hope I got the name right ) would work on a 94 4 cyl yj.
    Using a Ford dist. cap.
    Thanks Stan
    Re: team rush
    If in wrong section please move.
    Re: team rush
    Not sure what you're talking about, and if you got the name wrong we might never know what you mean. Can you describe what you're talking about?
    Re: team rush
    Looked it up. It is the TFI upgrade, bolt on dist cap adapter, upgraded cap & rotor,upgraded plug wires & updated coil. By TeamRush
    Anyone who's done the Motorcraft switch... - Jeep Wrangler Forum
    Read #3 & # 12 (for pictures)
    Would this work on a four banger 94 yj?
    Dec 1999
    Virginia Beach VA
    8,048
    Re: team rush
    He's talking about the TFI ignition upgrade. I did a full writeup here:
    http://www.jeepz.com/forum/engine/16...n-upgrade.html (TFI ignition upgrade)
    The TFI ignition upgrade replaces the small distributor cap and coil with an improved distributor cap, better wires, and a better coil. It made a huge different in my old 4.2 CJ7 - a very good upgrade.
    The pictures you linked to are not a TFI upgrade (that teamrush pioneered), but are instead a GM HEI setup. That is said to provide at least as much improvement.
    All this said, the part number aren't going to work for your 4 cylinder YJ. Everything researched for the TFI upgrade is for a 6.
    My 2005 Wrangler Build Thread
    Re: team rush
    Is there that would work on a 4 banger ?
  7. #7
  1. Thank you from ShopJeepParts.com Team
    By shopjeepparts in forum 4x4 Vendors
    Last Post: 01-01-2013, 02:27 PM
  2. Chrysler and Fiat to merge their management team
    By TerryMason in forum General Chat
    Last Post: 07-14-2011, 01:56 PM
  3. team rush Quality parts?
    By 5pd in forum Wrangler and CJ
    Last Post: 09-30-2009, 11:23 PM
  4. Replies: 0
    Last Post: 09-17-2005, 01:04 AM
  5. Colorado Team
    By Tug-n-pull in forum Events
