Thread: 304 to 258
  1. 304 to 258
    Hello guys! I have a huge question. I have a 79 cj 7 that is a paper weight in my drive way. It has the 304 and was built to perform. Well needless to say the top engine needs rebuilt. But since it's summer, I bought a 258 for a quick swap until the 304 can be rebuilt. Can you tell me if I need to get a new alt or carb? Do I need to relocate the fuel line? Get different motor mounts? I also found a 290 amc..I got the 258 for 300. Anyways, I'm just not sure what to do regarding the swap. Any help would be great
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: 304 to 258
    If the 258 doesn't have a carb, most likely you will need one. You will need to run the fuel line down the opposite frame rail from where it is now. One motor mount needs changed and they bolt on so that shouldn't be difficult ,cant remember which side it is. Use the same alt. That should be about it.
    Re: 304 to 258
    Thank you so much!
    Re: 304 to 258
    and you can use that same carb, if it will bolt to the intake. just depends on the carb
    03 rhd tj
    Re: 304 to 258
    Would I need to change the wiring harness?
    Feb 2012
    Cincinnati, Ohio
    1,993
    Re: 304 to 258
    No!
  7. #7
    Re: 304 to 258
    Awesome, always like saving money
  8. Re: 304 to 258
    258 can be all you need, they do burn the gas,no more then the 304, 258 rebuild is my pick, NP ? 432 four speed granny,Dana 300 w/advance adapter, thats a great set up
  1. jeep 258 to ford 302 swap
    By jprtroy in forum Wrangler and CJ
    Last Post: 03-20-2011, 09:16 PM
  2. 258 6cyl to 304 V8
    By mingez in forum Wrangler and CJ
    Last Post: 07-18-2005, 01:49 AM
  3. 4.0l to 258 swap
    By savin in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-03-2003, 06:26 PM
  4. i need info on swapping a 304 to a 350
    By TerryMason in forum Wrangler and CJ
  5. 258 to 304 swap
    By tdayley in forum Wrangler and CJ
Tags for this Thread
