Brake lights not working
RM1975CJ
I just bought a 1975 CJ5 and the brake lights aren't working, the running lights an turn signals are working, It appears to have a stoplight switch off of a 76 CJ I was just wondering if that is compatible with my jeep
and the metal under the mounting bolts is clean? I don't think the switch is different but you can google to see which one. has it always not worked since you have had it or just recently started
They are different, but would think they operate the same.
$11.57 $13.65different, but would think they operate the same.
$11.57 $13.65AC Delco C850A Brake Light Switch - Direct Fit
$21.96 $25.91You Save $3.95 (15%)
Add to Cart
Availability: In Stock, 1-2 Business Days
Earn 22 points!
Only from APW Rewards Be an AutoPartsWarehouse.com VIP and get more benefits than ever before, including earning at least 1 point for every dollar spent when you shop at APW. Click here for details.
ACDELCO OE REPLACEMENT BRAKE LIGHT
1608 × 1116 - quadratec.com
first one is for a 76, second one is for 66 and up depending, and third should be the one you need. The second one work off line pressure, you can follow your brake lines and see if you find one like, if so you will need that one.
