Rubbing / sticking
Are you talking about rear disc brakes, or the emergency brake?
I had a caliper not releasing enough away from the rotor on another vehicle and went thru a set of brakes in less than two weeks. It was in the caliper slide and not the piston.
Sent from my XT1650 using Jeepz.com mobile app
Calipers have glide pins that need to be greased when changing pads or adjusting brakes.
Overheating the breaks will cause the grease to melt away allowing for water oxidation and rust.
Also be sure it isn't the parking brake.
Or the dust shield rubbing.
JPNinPA
Using Jeepz.com app
Update. New brakes today. Did them myself and a friend this time. 2 pins froze and not moving freely. Rear inside pads were completely gone. Cleaned and properly lubed pins. Brakes work great now.
Sent from my SAMSUNG-SM-G891A using Jeepz.com mobile app
