Turn signals
The cause foe the signals to increase in speed is a change in resistance. So there is either a loose connection at the bulb, wiring at the bulb or in the column. Poor connection or short. Do any stop blinking when the wheel is turned? I assume you don't need to be moving to see this.
Regards,
JPNinPA
Sent using TapTalk
I agree with JPNinPA thoughts. If you concur with his last statement it would tend to isolate the issue to the column area by eliminating the lateral forces at work when driving and turning.
Sent from my XT1650 using Jeepz.com mobile app
What year make and model?
On Wranglers the multifunction switch goes bad but I would still expect wiring.
JPNinPA
Using Jeepz.com app
Try this first. Push your hazard light button a number of times then see if the issue persists. If it continues pull the covers off of the steering wheel and do a wiggle test of the wires to see if it's the wires or the switch.
Regards,
JPNinPA
Sent using TapTalk
