    Dec 1999
    Virginia Beach VA
    8,023
    How hard is it to replace a Wrangler manual transmission?
    I've got a line on a 1998 4.0L Wrangler with a manual transmission for 2k. It's said to have transmission problems, and requires a tow to get it home. I'm just wondering how hard it would be to replace the manual transmission in this Jeep. I've never done transmission work, however I have pulled my transfer case and install a SYE. I have air tools and a nice floor jack, but no transmission jack.
    I see the local pick-n-pull has a few Cherokees, which I think have the same transmission (AX-15 right?). If the moons line up I could get a junk yard transmission for about $130.
    What do you guys think?
    My 2005 Wrangler Build Thread
    Re: How hard is it to replace a Wrangler manual transmission?
    its just as easy as anything else. you don't need a specific jack either, I have never had anything but those little 2 ton walmart jacks. and a manual transmission is light so its really not bad
    Dec 1999
    Virginia Beach VA
    8,023
    Thanks superj. Turns out it was sold before I got to it. I figured a TJ for 2K was too good to last.
    Sold same day it was listed.
  1. How hard is it to replace an XJ transmission?
    By TerryMason in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-06-2015, 10:08 PM
  2. Replies: 0
    Last Post: 02-14-2013, 02:07 PM
  3. Replies: 3
    Last Post: 03-04-2012, 10:45 PM
  4. How hard is it to replace water pump on 4.0L YJ?
    By MudderChuck in forum Wrangler and CJ
  5. How hard to replace the rear seal in transfer case.
