1. 2001 4.0 Engine issue
    so my daughters jeep is begging me to sell it but i really dont want to. this little thing has given me fits since weve owned it.(bought it used) but i was ok with that, i figured once she is done with it then ill keep for myself and have a toy. but man this thing is stubborn, its as if it just doesnt like not having an issue. Ive been chasing a intermittent starting issue that i think i finally solved and now got hit with a new one. Friday my daughter was getting ready to leave school and it wouldnt start. i was thinking oh here we go again. but she said this time was different. So i get to her school and start, or try to start her jeep. it turned over but wouldnt start. so i feathered the accelerator and it would start but if i let off the accelerator it would instantly die. So to get home, which is only a couple of miles, i had to feather the accelerator and brake. once i get home i backed into the garage so it would be easier to work on, let off the accelerator it would stay running but it had a a really low idle. Not sure where to start so any leads would be great. Thanks everyone.
  2. Re: 2001 4.0 Engine issue
    Idle issues with the 4.0 usually points straight to the IACV " Idle air control valve ".
    Located at the throttle body, take it out and clean it, maybe 10 minutes. It's a very common issue but an easy fix.
    Feb 2009
    Dayton Ohio Area
    6,033
    As above clean the TB band IAC.
    Check fuel pressure.
    O2sensor
    Temp sensor
    CKP
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Engine Swap issue with '04 Grand Cherokee engine into '00 JGC Laredo
    By DivineImpressions in forum Wrangler and CJ
    Last Post: 08-03-2014, 08:12 AM
  2. 2001 Grand Cherokee Laredo Auto Trans Issue
    By David Black in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 09-08-2012, 02:23 PM
  3. 2001 GC Laredo transmission issue
    By st0new0lf in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 11-08-2010, 09:00 AM
  4. trans fluid need advice on 2001 wrangler engine
    By parosenb81 in forum Wrangler and CJ
    Last Post: 05-28-2009, 10:01 PM
  5. 2001 wrangler engine type
    By Eddie4x4 in forum Wrangler and CJ
