Help rough idle when i put into reverse
Swizzle83
My 95 jeep starts just fine i shift into reverse and it idles rough amd wants to die it is also doong rjis wjen i come to a stop on drive any help would be great
I'm assuming this is an automatic. What model Jeep is it?
so anytime you push the brake, its idles down and wants to die? is it using brake fluid? like you have to put it in the reservoir regularly?
Check your connection at the TPS
Actuate the TPS 25-50 times with engine off by opening and closing the butterfly valve.
Clean the IAC and TB.
If you replace sensors use OEM
JPNinPA
Using Jeepz.com app
