1. Front end popping
    I have a 07 Jeep Wrangler 4door jk when driving can feel a little pop in the front Thur the steering wheel everything feels tight under the front any ideas
    Re: Front end popping
    You need to jack up the front and carefully check all the steering and suspension components.
    Dec 1999
    Virginia Beach VA
    8,026
    Welcome to Jeepz.com
    Any chance you have a locker in the front? Stuck in 4wd?
    For my 2 cents I'd guess it's bad ball joints. Especially if the popping happens when you are on bumpy / uneven roads.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Quote Originally Posted by TerryMason View Post
    Ok thanks Ill check them out
    Feb 2009
    Dayton Ohio Area
    5,325
    Sway bar and sway bar links. Your sway bar can slide until one end catches the frame. Then possibly pop off the edge. Or if the links brake the bar separates and bangs down on the link going over bumps or rises.
    Regards,
    JPNinPA
    Sent using TapTalk
    Feb 2009
    Dayton Ohio Area
    5,325
    Also consider axel joints. Bad ujoint in an axel will bind on a turn.
  7. #7
    Found the problem its the upper ball joints going to replace all of them thanks for the help guys appreciate it
  8. #8
    Feb 2009
    Dayton Ohio Area
    5,325
    Well glad you got it fixed.
  1. Front End Popping Issue
    By Dirtgash in forum Wrangler and CJ
    Last Post: 05-19-2010, 12:04 PM
  2. clicking/popping front end
    By indiemo in forum Wrangler and CJ
    Last Post: 09-23-2005, 04:29 PM
  3. popping out of 2nd and 4th
    By frankiefire702 in forum Wrangler and CJ
    Last Post: 07-04-2004, 03:51 AM
  4. Something is popping
    By jeepguy_902003 in forum Wrangler and CJ
    Last Post: 11-30-2003, 05:57 PM
  5. Popping the ???
    By 83CJ701DakRT in forum General Chat
