    Sep 2019
    Dual living... Montreal Canada; Puerto Plata Dominican Rep.
    4
    Instrument cluster
    I have a Jeep Wrangler 2002 SE 2.5l 5M. The cluster is blocked at 888888.
    Daily is working...
    I remove the cluster, clean it with electric cleaner, I put dielectric grease on connectors,
    but still nothing...
    So, somebody can help me?
    Thanks
    Feb 2009
    Dayton Ohio Area
    5,325
    Re: Instrument cluster
    Check fuses. Specifically #4 behind glovebox.
    Run cluster diagnosis test. Reset pushed key to on let reset out.
    Check all pins are making contact in cluster.
    Regards,
    JPNinPA
    Sent using TapTalk
    Sep 2019
    4
    Thanks for the answer. The test is done more than one time. No changes. The only thing to do is to check the fuse, but I suppose that is good because is used also for something else... about the pins...I will try. When I strip the cluster I look at the pins and I didn't see
    any corrosion or bad connexion... Anyway... in vacation... with some beer aside I will check again.
    Feb 2009
    Dayton Ohio Area
    5,325
    Instrument cluster
    Usually pins are compressed metal and spring like. After some time and weight....the spring relaxes then bends until no connection. So the blade end may look fine but the opposite is the issue. I don't know how much space is there and if you could do this and monitor at the same time. But you should be able to wiggle or push the each wire connection from the backside to determine if it is one pin.
    Pic from a broken connector
    Regards,
    JPNinPA
    Sent using TapTalk
    Feb 2009
    Dayton Ohio Area
    5,325
    Found this if ever needed
    Regards,
    JPNinPA
    Sent using TapTalk
    Sep 2019
    4
    OK,Thanks I will try that also... in December when I go in vacation... This Jeep is in Dom.Rep. ... the mileage is not very important
    there but I don't like when something don't work properly...
  7. #7
    Sep 2019
    4
    Hi Guys,
    I found an other Cluster the same p/n like mine. Now...I like to know if its possible to check it if its work with out put it on the car.
    Thanks
  1. Instrument Cluster 01
    By 01jeepgc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 03-12-2015, 03:23 PM
  2. instrument cluster not functioning
    By bert37 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-16-2013, 09:11 AM
  3. TJ instrument cluster beeping
    By Crazy4diesels in forum Wrangler and CJ
    Last Post: 11-23-2010, 11:41 AM
  4. instrument cluster
    By tjc in forum Wrangler and CJ
    Last Post: 07-22-2009, 10:16 PM
  5. If anybody needs an instrument cluster...
    By IRPancake in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 08-23-2008, 08:48 PM
