1. JK turn signal issue
    Iíve got a 2016 Wrangle Unlimited Sahara. The right rear brake light and turn indicator donít work. When switched, the interior dash light flashes rapidly with a rapid clicking noise. The bulbs are good and the fuse is also good. Any recommendations on solving this problem?
    Feb 2009
    Dayton Ohio Area
    5,385
    Are the new bulbs LED?
    Do you have a brush guard around the blinker housing?
    Or a CB antenna mounted behind the housing?
    If not check that the bulb is seated properly. And the ground to the bulb holder is good. The relay is expecting a certain resistance if a bulb is burnt the resistance is too low and it clicks fast. This same thing happens with LED bulbs and a stock relay.
  1. Replies: 6
    Last Post: 08-12-2019, 10:36 AM
  2. Fog Lamp, turn signal issue?
    By Chris10 in forum Wrangler and CJ
    Last Post: 07-11-2016, 09:36 PM
  3. 2000 grand cherokee turn signal hi beam issue
    By Fatherkey in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-27-2013, 02:58 AM
  4. Brake/Turn Signal issue
    By Bob Snow in forum Wrangler and CJ
    Last Post: 02-17-2013, 08:41 PM
  5. CJ7 Turn Signal Canceling Cam Issue
    By dave_denn in forum Wrangler and CJ
    Last Post: 01-21-2010, 09:06 AM
