1. jeep dosent ide right
    97 jeep 1997 2.5 wrangler
    when i start jeep when its a cold engine it sputters idle s so rough it has died i have to restart i have replaced so many things thinking it would be the problem but it still does it does anyone know maybe if i have a bad coil causing problem or ecm if i let it warm up to 200 degrees everything seems ok but first time starts terrible im at a lost
    Feb 2009
    Dayton Ohio Area
    5,441
    Check that your temp sender is reading correctly. There may be two one for the gage and one for the PCM. Check the one for the PCM. Other than this a slow upstream O2 can do this.
    Any CEL
    Regards,
    JPNinPA
    Sent using TapTalk
  1. Newbie dosent no
    By Buck hour in forum New Member Introductions
    Last Post: 11-29-2010, 06:35 PM
  2. Left Turn signal dosent work, but flasher works fine
    By cundifc in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 12-30-2009, 08:55 PM
  3. Driver door dosent close well
    By 93bizzleYJ in forum Wrangler and CJ
    Last Post: 09-10-2003, 08:24 PM
