2004 wrangler brake and caliper help please!
Hi im trying to replace the caliper on my newly purchased used wrangler got the brakes on the calipers with no issue. However when mounting the pins the wouldnt grip and stay in due to being rusted and stripped out on the mount. So i took advice and got the helicoil. Tried drilling it out and the bit snapped off inside and cant get it out so bow i guess its time to replace what the caliper is mounting to. However i dont know exactly what it is im looking for or looking to replace since the 04 wrangler dont have independent caliper mounting brackets. Any help would be very greatly and eternally thankful.
You could still drill that out.
You need a harder bit and come from the other side if the bit was hardened you may be able to shatter it out. Be careful pieces are sharp like glass.
Had to look it up. I'm confusing parts with my other vehicles.
New knuckle.$60
