1. 1997 wrangler heat/AC unit
    Hi, my 1997 Wrangler I just purchased had the air comes out all vent, it cold but I want it corrected. What I found the “the Panel/Demist door actuator and defrost door actuator are tied together. It must have it reason to be tied together and if I remove I may lose my ac in the Texas in July. Ever see this being tied together or why? Thanks Tim
    Dec 1999
    Virginia Beach VA
    8,071
    Re: 1997 wrangler heat/AC unit
    On my 2005 Wrangler, the controls that direct where the airflow goes is vacuum operated. When You get a vacuum leak somewhere, it generally causes the AC to come out only the defrost vents. Is this similar to what you are seeing?
    My 2005 Wrangler Build Thread
    Feb 2009
    Dayton Ohio Area
    5,649
    Pic would be good.
    Possibly the door pin is was broken?
    Here is a write up on the actuator causing issues but a pic would give more in-site. Jeep Wusses - Quick Heater Fix - Jp Magazine
    Just for clarification. Air comes out all vents no matter what selection.
    Is the blend door and select door intact?
    Pics please
  1. 98 Wrangler Heat Issue
    By Bomberbeer in forum Wrangler and CJ
    Last Post: 10-21-2011, 12:12 PM
  2. 97 wrangler heater don't heat
    By DuffTrucks in forum Wrangler and CJ
    Last Post: 12-08-2009, 05:08 PM
  3. 1997 wrangler
    By drew32 in forum Wrangler and CJ
    Last Post: 08-05-2009, 11:22 AM
  4. no heat in my 1997 jeep cherokee
    By PicklePerk19736 in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 02-01-2009, 01:29 PM
  5. 1997 wrangler
    By mufflerman in forum Items for Sale, Trade, or Give Away
    Last Post: 06-21-2006, 08:11 PM
Tags for this Thread
