Thread: MSD Ignition
    1070091
    I am thinking about putting a MSD ignition in my jeep. Will this work with a 4 banger. If so how hard will it be to hook up. I can't find much info on this. :-? [addsig]
    90yj 2.5l 4.5RE EX duty,1\" body lift,33 12.50 BFGKM\"S,Clifford Header,High Flow Kat,K@N FlowMaster,Flex-a-lite Fan,MasterCraftSeats, 4.88\'s, ARB,Full Cage,Currie SYE,Tom Wood CV Driveshaft,JKS Quick Diss.
    Real Jeeps Are Built Not Bought!
    Oct 2002
    East Tennessee
    5,149
    1070092
    Good question there seems to be so much stuff for the I-6 but so little for the 4 bangers. tug
    [addsig]
    1070093
    If thay were to make more stuff for the pre 91 4 banger there would be so many happer older yj 4 Banger jeepers. There would be such a market for it. There's not much for the pre 91's.
    edited by: JE420EP, Jun 06, 2003 - 01:15 AM[addsig]
    Oct 2002
    East Tennessee
    5,149
    1070095
    You just made the first step in a profitable market research. Now the trick is to research and development and you are on the way to being a millionair. What do the pre 91 bangers need and what would it take to make the said item a tangable item. Tug[addsig]
    1070471
    I doubt you will need a MSD in a 4 cyl. I don't think your engine will need that much spark. I would be worried about fouling plugs left and right.
    Just a thought though
    shouldn't be too hard to hook up, same as any vehicle.
    Try to adjust the timing, if the timing is at all retarded, just advance it a degree at a time to get optimal spark.[addsig]
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
