Thread: high oil pressure
07-20-2003, 08:00 PM #1
1070734
i have a 1990 yj and she usually idles with about 40 pounds of oil pressure. But when i am driving it buries up past 80. normal or not?[addsig]
07-20-2003, 08:00 PM #2
1070736
what weight oil are you using?[addsig]
07-20-2003, 08:00 PM #3
1070740
10w 40[addsig]
07-20-2003, 08:00 PM #4
1070772
I had the same issue when my 89 was new and dealership replaced sending unit. That's all I can tell you.[addsig]
07-20-2003, 08:00 PM #5
1070775
07-20-2003, 08:00 PM #6
1070816
well.. you don't want your crank to me pressurized really... you can blow a freeze plug (softplug... etc..)... it is often the result of a faulty pcv system[addsig]
93 YJ 4.0
07-20-2003, 08:00 PM #7
1070934
PCV is new crank case breather is new. Still runs high. tug[addsig]
07-20-2003, 08:00 PM #8
1070950
BBJ has a fauly gauge... as soon as he starts it... it pegs full... with occasional drops in the readings[addsig]
93 YJ 4.0
07-20-2003, 08:00 PM #9
1070962
hey, I have a 89 YJ and it runs about 70 to 80psi when I am driving and 30 to 35psi at idle. I did some research on this because it seemed high, but the manual says the oil pressure is supposed to be 25 to 35psi at idle and 37 to 75psi over 1600 RPM. I hope this helps!![addsig]
