    Will a front disk brakes from a 77 CJ5 bolt onto a 74 CJ5 axle?
    I've recently acquired a stock '74 CJ5 project jeep, and have the opportunity to pick up a stock '77 CJ5 for parts. The '74 will be kept relatively stock for farm use as well as the occasional trip to town.
    Will a front disk brakes from a 77 CJ5 bolt onto a 74 CJ5 axle?-jeep-trailer.jpg
    My main motivation regarding acquiring the '77 is that it has disk brakes on the front end, versus drums on the 74.
    What are the differences between the two axles? Thus far I discovered that the spring widths may be different, but I have not found out if the front disk brakes, master cylinder and power assist from the '77 would be a bolt on to the 74 axle.
    Can anybody steer me in the right direction?
    Thanks much.
    Scott
    Feb 2009
    Dayton Ohio Area
    6,013
    Easiest way to determine is compare replacement parts. You could do this on a website lookup. Rockauto, OReillys, AZ...NAPA
    One thing to be some to be leery of is hat height on rotors. This doesnt have rotors but others will read this as general knowlege.
    Re: Will a front disk brakes from a 77 CJ5 bolt onto a 74 CJ5 axle?
    JP, thanks for the response. Unfortunately disk brakes were not an option in 1974, so there are not any replacement part comparisons available from the standard auto parts suppliers.
    Feb 2009
    Dayton Ohio Area
    6,013
    Never mind. Sorry I understand what you are asking now.
    My initial response was not what you needed.
    From 1972-1983, the Dana 30 was used in the CJ-5.
    Never mind. Sorry i understand that you are asking now.
    DIY Jeep CJ Front Disc Brake Conversion under $100! Made From Spare Parts! - YouTube
    Thanks for the link!
  1. 2002 Jeep Grand Cherokee. Front axle track bar mount (on the front rear)
    By PhillyXtrememotorspirts in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-03-2019, 09:17 PM
  2. Jeep JK 1 Ton Axle Swap Kit GM 14 Bolt Rear
    By motobilt in forum 4x4 Vendors
    Last Post: 03-02-2018, 11:33 AM
  3. Replies: 16
    Last Post: 12-12-2013, 02:01 PM
  4. The C&C 14 Bolt Disk Bracket!
    By Dan Fredrickson in forum 4x4 Vendors
    Last Post: 11-04-2012, 10:37 PM
  5. Axle swap to disc brakes?
    By Bill Arwood in forum General Chat
    Last Post: 07-27-2008, 06:30 PM
Tags for this Thread
