Thread: Central Axle Disconnect Lines?
11-22-2020, 03:13 PM #1
My 4WD quit working last winter on my 94 YJ Wrangler and I let it be for the year and now winters coming around and I want to get it fixed. I went under it and saw there weren’t any lines to be found connecting to the vacuum diaphragm on the CAD and have no clue where the lines would connect from. Any got any diagrams to point me in the right direction ?
11-22-2020, 05:08 PM #2
Re: Central Axle Disconnect Lines?
This diagram was labeled as a 1995 2.5L 4x4 hose routing. I think it's what you're looking for.
My 2005 Wrangler Build Thread
11-23-2020, 07:49 PM Thread Starter #3
That is EXACTLY right! Thanks terry. Found a cracked suction line that is supposed to kick on when you put it in 4WD so I clipped that and reattached good line and found rusted hole in diaphragm so I bought a whole new setup. Very helpful!
11-23-2020, 08:18 PM #4
Alright! I'm glad it's working.
95 YJ ABS lines- more length or disconnect?
By Crew11 in forum Wrangler and CJReplies: 1Last Post: 02-19-2008, 09:22 PM -
Front Axle Disconnect?
By beachjeep in forum Wrangler and CJReplies: 15Last Post: 03-12-2004, 11:41 AM -
Arrrgh need help....broke my axle disconnect system....
By berettajeep in forum Wrangler and CJReplies: 8Last Post: 07-20-2003, 08:00 PM -
I don't have an axle disconnect.
By Bounty__Hunter in forum Wrangler and CJReplies: 4Last Post: 07-20-2003, 08:00 PM -
By Tug-n-pull in forum Wrangler and CJReplies: 6Last Post: 07-20-2003, 08:00 PM
