1999 Jeep Wrangler
overhypedd
Hi All,
Need some help. Jeep is quick jerk/pull to the right when down shifting/decelerating and also when shifting and accelerating. Any tips on what it might be? I know it needs an alignment for sure, but any other pieces that could be failing?
It rides fine when not doing either even up to 80mph.
Thanks,
Ryan
Not sure.
Are you in 4WD or 2WD?
Bad springs or shocks.
Do you know if you have an open rear, slip, limited slip, posi or locked rear? Most rears only power one rear wheel in turn producing a torque steering. Bad components and alignment will worsen it.
