Thread: Actuators
    Actuators
    Went to change the actuator that is supposed to be under/near the steering column and there is nothing there. Not even a plug to hook it up too. Am I missing something.
    The Jeep blows cold air on the drivers side.
    Dec 1999
    Virginia Beach VA
    8,085
    Re: Actuators
    Welcome to Jeepz.com Guiness
    What year and model Jeep do you have?
    Are you saying that the air never gets warm, or that you can't switch from foot to defrost?
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Re: Actuators
    2008 Wrangler JKU. The air on the drivers side blows cold air.
    Feb 2009
    Dayton Ohio Area
    5,800
    Actuators
    Are all blowing cold air or just driver side?
    Did you verify the heater core is not blocked or restricted?
    Number 3 in this diagram has the recirculate/outside blend door.
    I believe you go in through glove box opening to access. EDIT: this is not for JK. Sry see video below.
    Air Conditioner and Heater Units for 2008 Jeep Wrangler | Jeep Warehouse Direct
    Re: Actuators
    Just the drivers side is blowing cold air. Heater core isn’t blocked
    Feb 2009
    Dayton Ohio Area
    5,800
    Actuators
    How do you know the heater core is not blocked?
    Did you test it or flush it?
    I believe the right is separate from the left in airflow through the heater core. And the core is a top down flow with entry parallel to the exit so if its going to clog sediment is likely to rest on the left(driver) side.
    Also there are many threads out about casting sand clogging up the core.
    I suggest crimping the rubber hoses to the core with vise grips. Disconnect the lines and back flush the core with a hose. Reconnect. Remove crimps. Burp the system and top off.
  7. #7
    Re: Actuators
    The heater core was flushed by a mechanic. Every vent is fine except the drivers side and the actuator is not there. Not even a connection for one
  8. #8
    Feb 2009
    Dayton Ohio Area
    5,800
    Actuators
    Well Im out of ideas. If air comes out, just cold its not a blocked duct. Nor an core blocked from air flow. Blend doors usually effect both sides.
    Air in the system or blocked core. Maybe blocked enough it needs to be replaced.
    Please post back if you figure it out.
  9. #9
    Feb 2009
    Dayton Ohio Area
    5,800
    Actuators
    TJ larger tubes, distributed inlet, single plenum. If one tube blocked all the air is h heated by others.
    JK
    Small fins, longer distribution, not distributed and left right plenum. If the left (farthest from inlet)blocks only right is heated.
  10. #10
    Feb 2009
    Dayton Ohio Area
    5,800
    Re: Actuators
    2015 Jeep Wrangler JK AC Blend Door Actuator Replacement - YouTube
  11. #11
    Re: Actuators
    Thanks for trying. I have bigger issues now lol. It won’t start or shift into gear if it does. The hydraulic/oil cap had a split in it and when I changed it everything else happened.
  12. Re: Actuators
    Put the broken cap back on.
    Needs to go yonder.
  13. #13
    Re: Actuators
    I am when I find it. Of course it’s not where I left it.
  14. #14
    Feb 2009
    Dayton Ohio Area
    5,800
    Re: Actuators
    Your oil cap?
    Changed it snd it will not start?
    Does it start with it removed? Blow by pressure??
  15. #15
    Re: Actuators
    Yes I changed it because it was cracked and was reading that could possibly be why it’s leaking hydraulic fluid wanted to try the cheapest route first.
    There was an insert on the new cap that I removed and now it starts and goes into gear.
    it could possibly be the master cylinder although you can’t see where it is leaking from. Or a gasket or seal somewhere.
  16. #16
    Feb 2009
    Dayton Ohio Area
    5,800
    Actuators
    Pics please!
    Wipe it down. Hit it with parts cleaner. Start it and take pics of where you see the leaks,
    Also when you hydraulic fluid what fluid?
  17. #17
    Re: Actuators
    Pics please!
    Ill take pics tomorrow. It’s dark out now. Hit what with parts cleaner? Never see any leaks, just fluid on the ground. Don’t know the name of the hydraulic fluid but it’s the only one the parts store carries here and it is for hydraulic clutches.
    Ok after closer inspection it appears to be the reservoir itself is where the leak is coming from.
  18. #18
    Feb 2009
    Dayton Ohio Area
    5,800
    Re: Actuators
    The clutch fluid?
    Think you found the issue. If its in gear and you start it it will try to move the vehicle or clutch will slip. If in neutral it will start but you cannot disengage the clutch.
    A primed slave cylinder and reservoir is inexpensive and easy to replace. 1 hr in the driveway with a few tools. Nothing special.
Tags for this Thread
