1. trouble removing d-rings shackles from my new to me rock slide engineering bumpers
    sorry if it has been already covered.i had no luck on the search engine.i soaked my d-rings 2 nights with pb blaster they will not budge.how can i remove them.i need to get them off before i get my bumpers line-x.
    Dec 1999
    Virginia Beach VA
    8,121
    Re: trouble removing d-rings shackles from my new to me rock slide engineering bumper
    If they are like mine, they have a flat portion with a hole in it.
    trouble removing d-rings shackles from my new to me rock slide engineering bumpers-230485.jpg
    I know that you can put a screwdriver in the hole and twist. I've also used a very large crecent wrench (or regular wrench) to turn the flat part
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
    Feb 2009
    Dayton Ohio Area
    5,956
    If you will not damage other items, use heat. Heat the nut end up cherry hot and then try. The delta in thermal expansion between metal and rust, breaks the rust. Then penetrating oil can work. Twist the bolt end back and forth. Any movement further breaks down the rust.
    Get some big channel locks and put it on the flat end of the screw and either depending on direction the screw is facing put the ring against the bumper(only do if you have steel bumper) and push down on the channel locks. If its the other way threading do the opposite. Channel locks on bumper and push on the ring its self. Works for me every time
    Thanks to all who replied.I tried Jaredh's idea with the channel locks & they came off .
    Sent from my SM-G965U using Tapatalk
  1. Trouble removing starter
    By Jason Bland in forum Wrangler and CJ
    Last Post: 10-19-2012, 06:53 PM
  2. New Style 17X8 Rock Crawler Rims with Bead lock rings
    By Wolfsmate79 in forum Items for Sale, Trade, or Give Away
    Last Post: 10-05-2006, 11:38 PM
  3. Just received my Rock Krusher Bumpers!
    By montana_jeepn in forum Wrangler and CJ
    Last Post: 07-28-2003, 02:37 PM
  4. Trouble removing crank shaft bolt....harmonic balancer
    By Lhotak92XJ in forum Cherokee, Commander, Wagoneer and Liberty
  5. Rock Krusher Bumpers
    By jhiggins in forum Wrangler and CJ
Tags for this Thread
