    2005 TJ windshield frame and bolts seized, broken, extractor snapped off..HELP
    Long story short:
    2005 TJ with broken windshield & rusted windshield frame both need replacing.
    Half of the torx bolts on both sides were seized...and then stripped...
    I've tried:
    • PB Blaster to loosen them,
    • a torch,
    • dremmeling a slot ,
    • drilling them out and
    • inserting an extractor.
    This worked on only two of the bolts.
    Three..of them have broken drill bits or broken extractor tips inside them.
    What do you do when penetrating spray, torch, dremmeling, drilling, and extracting don't work?
    I'm literally thinking about hacksawing the window hinges and having the new window frame welded on.
    Any thoughts?
    Dec 2010
    California
    527
    Re: 2005 TJ windshield frame and bolts seized, broken, extractor snapped off..HELP
    Try Liquid Wrench, wet the bolt, then lightly tap tap tap with a small ball peen hammer. The tap tap tap helps the Liquid Wrench get into the threads. Repeat every few hours for 24 hours. Then try the removal things you already tried again.
    Feb 2009
    Dayton Ohio Area
    6,430
    When you are that far in... Im not sure. When drilling out use cobalt drill bits and lubricate. The bits are hard but shatter if you push too hard or bend the bit. If you break a bit diamond is the next hardest.
    The bolts have loctite from the factory. Using a sharp torx bit and cleaning out the bolt of paint or debris. Make sure it the torx is a tight fit. PB blaster soak. Put the torx bit in and heat with a torch to soften the loctite. Tap it a few times. Start to loosen. Do not use a breaker bar as you are likely to strip the bolt quickly. When you get the bolt to move a bit rock between tightening and loosening. Reheat between. The rocking breaks up the rust and allows the penetrating oil to work.
    ^^ditto on the tapping the back of the torx bit after heating.
    Feb 2009
    Dayton Ohio Area
    6,430
    2005 TJ windshield frame and bolts seized, broken, extractor snapped off..HELP-image1619401459.341474.jpg
    This is sharp. Note no rounded edges.
  5. Re: 2005 TJ windshield frame and bolts seized, broken, extractor snapped off..HELP
    Also, sounds crazy, but has worked. Tighten it, then loosen it repeat.
    Needs to go yonder.
    Thanks to everyone for their input. I ended up buying Irwin Cobalt drill bits and drilling out the torx bolts that were stripped. It was a nightmare, but I finally installed my new windshield frame and glass. From now on I will assume that I everything on my TJ is fused together. I will never 'believe" any bolt is removable. No screw can be unscrewed. It is just one monolithic piece of metal. Then I will never be disappointed or surprised again.
  7. #7
    Feb 2009
    Dayton Ohio Area
    6,430
    Glad you got it done.
  8. #8
    Dec 1999
    Virginia Beach VA
    8,221
    I've got one of these that works well
    Amazon.com
    You hit it with a hammer, and it both presses the bolt tight, and turns it a few degrees. Works well for really bad bolts. You'd also need a torx adapter.
    My 2005 Wrangler Build Thread
    He who is without oil shall throw the first rod. -Compressions 8.7:1
  9. #9
    I bought one of those 30 yrs or so ago, don't use it often but it does come in handy when you do need it.
  10. #10
    i have one also, that is many years old.
    03 rhd tj
  11. #11
    Feb 2009
    Dayton Ohio Area
    6,430
    Quote Originally Posted by TerryMason View Post
    Amazon.com
    Clean the paint and gunk out of the corners in the torx bolt. Soak with PB blaster. Put the sharp torx bit in. Heat the bit to near red hot then attach impact and give it a wack.
    Heat loosens any rust or thread lock,
  12. #12
    what i have found works the best on breaking torx bits out is just using a longer lever arm. those short 10-12 ratchets require a lot of force to break a torx and you end up leaning or not applying force squarely and stripping the torx. i have a 24 and 30 inch ratchet so i can put the bit into the head and just leisurely apply pressure t the end of the ratchet and the bolt comes smoothly out
    03 rhd tj
  13. #13
    and i am like you, jobo. i live on the gulf coast so i have the dang salt air on everything. its less than half a mile from my house to the water
    03 rhd tj
  1. Broken Bolts
    By Brads94 in forum Wrangler and CJ
    Last Post: 04-13-2011, 08:50 PM
  2. Broken bolts on CJ7 transmission crossmember
    By peterblesi in forum Wrangler and CJ
    Last Post: 09-06-2010, 09:46 PM
  3. Windshield Frame Bolts
    By 88YJ6 in forum Wrangler and CJ
    Last Post: 08-05-2007, 12:38 AM
  4. rollbar to windshield frame mounting bolts
    By TomL in forum Wrangler and CJ
    Last Post: 04-01-2005, 06:54 PM
  5. BROKEN BOLTS IN MY TUB!
    By Jeeper84 in forum Wrangler and CJ
    Last Post: 10-31-2004, 12:55 AM
Tags for this Thread
