1. Screws rusting on my 15 rubicon cowl and windshield pillar
    I want to replace my rusty screws with rustproof ones.Not sure if I'm even naming the area where the screws are correctly.its a total of 12 screws.4 of them have plastic washers.the others are bigger. My question is where can I find a rustproof set.My guess would be stainless steel or can I get them in black like oem that won't rust?
    Sent from my SM-G965U using Tapatalk
    Feb 2009
    Dayton Ohio Area
    6,020
    These?
    Screws rusting on my 15 rubicon cowl and windshield pillar-image1623903699.118452.jpg
    If so use a sharp edge tight fitting torx. Put the torx in and heat with a torch or inductive heater to flow the loctite then unscrew. You might go between tighten and loosen and soak along the way with PB blaster. Keep hot until you get a few turns out.
    These strip easily.
    Re: Screws rusting on my 15 rubicon cowl and windshield pillar
    Yes sir exactly. Where can I get rustproof one'? Any ideas?
    These?
    These strip easily.
    I would like them to be black but I guess if I can't they will be stainless steel
    Quote Originally Posted by CINCOCERO View Post
    Feb 2009
    Dayton Ohio Area
    6,020
    Ace hardware, fasenall or any number of places. Just match shank and thread
    Thanks got them
  7. #7
    Feb 2009
    Dayton Ohio Area
    6,020
    Thanks got them
    Cool
    Would love to see the finished product.
  1. Windshield screws 93 yj
    By IanJeep in forum All other Jeep models
    Last Post: 07-13-2020, 11:26 AM
  2. Jeep JK LED Cube Windshield / A-pillar Mounts
    By motobilt in forum 4x4 Vendors
    Last Post: 04-22-2016, 04:10 PM
  3. Jeep JK LED Cube Windshield / A-pillar Mounts
    Last Post: 06-04-2015, 06:21 PM
  4. 1987-1995 Jeep Wrangler Windshield Cowl Seal
    By 1ATony in forum 4x4 Vendors
    Last Post: 12-02-2009, 04:41 PM
  5. a RUSTING j-10
    By Tug-n-pull in forum General Chat
Tags for this Thread
