    Transfer case shift linkage
    Today, at the off-road park, I lost 4 lo. My transfer case would shift into 2 hi, 4 hi & neutral but no 4 lo, just a spongey feeling in my shifter where 4 lo should be... well, I went to the articulation area to get a good look under the Jeep at the linkage and this is what I found.
    I'd rather not have to replace the linkage as is ridiculously and needlessly complicated... but I couldn't do anything on the trails but curse my ham hands because I kept finding the exhaust with the back of my wrist... waiting until it cools down then I'm going to see if it came unscrewed (hopefully) or broke 💀
    The Proud President of the CAN'T HURT DIRT MUD SLINGERS
    'Cause you can't hurt dirt!
    Zach Harpst
    Re: Transfer case shift linkage
    Dang, that doesnt look good
    03 rhd tj
    Dec 1999
    Virginia Beach VA
    8,421
    I have a similar problem on my TJ. It looks like we have different linkage, but on mine at least, the fact that I have a body lift has changed the geometry. It ends up being "if you can't find it grind it".
    Feb 2009
    Dayton Ohio Area
    6,782
    Quote Originally Posted by TerryMason View Post
    Terraflex makes a part to correct it for TJs
    Feb 2009
    Dayton Ohio Area
    6,782
    Part of that cable is rubbing on the drive shaft. Not good!!!
    Slowly cutting it or swiftly ripping it out.
    That's only when I'm trying to shift into 4LO. 2HI/4HI/N don't make the cable bulge out like that. I bought the B&M upgraded cable & bracket... no instructions on the box & limited instructions on the internet.
    Zach Harpst
  7. #7
    Dec 1999
    Virginia Beach VA
    8,421
    I ended up buying the Novak shift cable. It should be here later this week
    The Novak #SK2XC Cable Shifter Assembly for the 231 & 242 Transfer Case in Jeep TJ Wrangler, XJ Cherokee and MJ Comanche
  8. #8
    Cool
    03 rhd tj
  9. #9
    There's a bracket on the driver's side of the transfer case that I can only undo the lower bolt (and that was a feat in itself). The new bracket moves where the cable attaches further away from the t-case so the stock bracket has to go. I tried undoing the crossmember that cradles the t case to get better access but that didn't work. Instructions are as clear as mud & the help line was a joke. They both told me to "just unbolt it" like the Instructions say to
    Zach Harpst
  10. #10
    can you put 2 or 3 feet of extension on the ratchet and get it from farther back?
    thats how i have to pull the bolts for some bmw bell housing bolts. i lay by the back wheels and feed the extensions up along the driveshaft and upto the top bolts, which are a dang 11mm. what the heck
    03 rhd tj
  11. #11
    Quote Originally Posted by superj View Post
    I'll see what I can do. That top bolt is at the top of the t-case facing front but I'll see if there's another angle of attack.
    Zach Harpst
  1. Transfer Case Shift Linkage
    By dknudsen in forum Wrangler and CJ
    Last Post: 03-18-2015, 10:59 PM
  2. TJ transfer case shifter linkage
    By prariepunk in forum Wrangler and CJ
    Last Post: 02-20-2014, 12:15 PM
  3. Transfer Case Shift Linkage Upgrade
    By JeepMonkey in forum Wrangler and CJ
    Last Post: 04-14-2012, 12:59 AM
  4. transfer case linkage
    By jakbob in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 06-05-2010, 09:03 PM
  5. Transfer Case Linkage ???
    By lethaldose in forum Wrangler and CJ
    Last Post: 12-30-2006, 01:27 PM
Tags for this Thread
