    Dec 1999
    Virginia Beach VA
    8,419
    What are these things under my Wrangler TJ's battery?
    I was working on my 2005 TJ, and pulled the battery out. Under the battery there were two things that caught my eye:
    1. the battery plate has what appears to be a pressure switch. Is that what it is? I'm guessing it cuts power if the battery "escapes" it's tray. Is that correct?
    2. under the tray, there is a box with what appears to be a vacuum line coming in, but nothing else. It's bolted to the fender. I have no idea what this is.
    Can anyone ID this stuff?
    Feb 2009
    Dayton Ohio Area
    6,780
    That?s Joe and Frank.
    That ?pressure switch? is a battery temp sensor. Lets the PCM know battery temp so it doesn?t overcharge when hot.
    The vacuum line box is a vacuum reservoir. If removed or cracked your HVAC control will stop working. Some models had vacuum lockers that would branch off of the box.
    Dec 1999
    Virginia Beach VA
    8,419
    Re: What are these things under my Wrangler TJ's battery?
    I would have never guessed either of those!
    The battery temp sensor has a spring on it, I assume so that it can stay pressed up against the battery. Pretty cool design.
    Thanks!
    That vacuum box on mine came loose and was the source of a rattle that took me a very long time for me to find. Like months of looking, removing things, tightening things and so on. It was very frustrating.
  5. Re: What are these things under my Wrangler TJ's battery?
    i hppe my 94 wrangler is a basic beast without all the cool $hit yall got.
    Needs to go yonder.
    I thinkn94 has the battery sensor too. I know it has a vacuum canister on it
    03 rhd tj
  1. Things to look for on my CJ-7
    By skipdunning in forum Wrangler and CJ
    Last Post: 03-13-2017, 12:52 PM
  2. Things to look for
    By skipdunning in forum General Chat
    Last Post: 03-03-2017, 01:10 PM
  3. Big things are coming
    By stumblnyj in forum Wrangler and CJ
    Last Post: 04-18-2013, 10:26 PM
  4. what are some of the little things you have done
    By YuriSouder in forum Wrangler and CJ
    Last Post: 02-04-2009, 02:24 PM
  5. 100 things a man should know how to do.
    By Utah_jeepster in forum General Chat
    Last Post: 09-29-2008, 07:49 AM
Tags for this Thread
