1076943
Turn of your Jeep. No key in the ignition. Get a voltage tester and look for a wire under the dash (there should be one in the radio harness) and look for a 12 V. power source. Once you find it, splice into it and you should be fine. If it is on the car, it will have a fuse in it.-Al[addsig]
