Who has 37 inch tall tires...
Re: 1042086
so is that all. Anybody with 37 or bigger with both dana 44er's. See I want a new front axle and I also want 37's and be my everyday driver. Should I get a reverse dana 44 up front or reverse 9in.?or tera 50R or reverse dana 60?????????
I have 36 baja's on mine and did the ford 8.8 axel swap on the rear with 4.10 gears. The ford 8.8 is a nice cheaper upgrade if you have a little time.
thnaks for the info. Ok maybe I should ask it like this. Who runs a Reverse rotaion dana 44 up front with 4.56 gears? What's bad about it and what don't you like, also what has broke?
Ok what about my rear dana 44 that is locked with an ARB with 30 spline axles and 4.56 gears. With a full floater kit will it be strong enough? Thanks AJ
