    Squeeky springs
    How do you put that funny looking rubber gasket that comes with the timing gaskets? I am talking about the oil pan part. I didnt replace that gasket when I did my timing chain.
    I am going to invent WET
    White Entertainment Television
    www.cardomain.com/id/bryanjeep
    It should have little rubber nubs that pull through small holes in the lip of the oil pan. You also need some oil resistant silicon to seal the ends were it meets the block. I haven't seen the '94 4cyl, but most other engines I've seen have this setup.
