Clutch problem - posting this for another
TerryMason
Administrator
Staff member
266000
-I'm posting this for Glenn,
Terry-
I HAVE A 1984 CJ-7 AND I JUST REPACED ALL OF THE CLUTCH PARTS THAT I KNOW
OF.I INSTALLED A NEW CLUTCH AND PART FROM THE FORK ALL THE WAY UP TO THE
PEDAL . EVERY TIME I GO OVER A BUMP IN THE ROAD IT SEEMS THE CLUTCH PEDAL
MAKES A NOISE . HAS ANY ONE FOUND THIS PROBLEM WITH THERE JEEP. I CAN NOT
FIND OUT WHAT MAKES THIS NOISE. THE PEDAL MOVES A LITTLE WHEN YOU GO OVER
THE BUMPS. PLEASE E- MAILS ME I NEED HELP WITH THIS. THE JEEP RUNS FINE AND
THE CLUTCH WORKS FINE.
MY BE SOMEONE HAS HAD THIS PROBLUM AT SOME TIME WITH THERE JEEP.
Glenn Davis
267000
I havent had this with my jeep, but have experienced it with other vehicles, you may want to check your clutch pedal return stop (bolt/screw at top of pedal similar, to steering stops)
