1.5" shackles & 2"body lift
rtoney9
I got my Jeep 95 YJ in May 2002. I want to make some modifications to it for off road use, but not too much. If I put 1.5" shackles & a 2" body lift what size tires would look best on it? Also, what is the biggest size tire that will fit on a 15x8 wheel? thanks
[addsig]
1041818
31"s if you like a little room, 32"s would probably be the biggest you can fit. This is assuming your stock springs haven't sagged at all.
The widest tire you can safely fit on an 8" wheel is 12.50".[addsig]
1041829
thanks for the information. It helped alot. I'll let you know when I get her dressed up.go muddin
[addsig]
