I just got a 258 out of an 84 eagle car and i'm going to swap it into my '87 wrangler. The engine mounts on the pre-87 258's are the flat single stud kind and they switched to the newer kind in 87. My question is, will the engine mount arms from the 87 bolt up to the 84 block? Did AMC they keep the same block casting and just redo the mounts? The bolt holes look to be in exactly the same places but I just wanted to be sure.
od
od
