Home made discos
Green97TJ
I know ive seen something on here before about converting OEM sway bar links to disconnects, any of you guys know what im talkin about? what i need? Or even better, if someone can link me to a good write up id appreciate it. I figure its pretty simple, but id like to know for sure.
Thanks
Nathan
I don't remember the exact sizes of the hardware, but here's how mine's set up:
http://www.azbackcountry.com/pics/763_04117161235.jpg
http://www.azbackcountry.com/pics/763_04117161257.jpg
If you reuse the factory washer don't use it against the back end of the clevis pin the hole diameter is a little too large and it will eventually strip the head off of the clevis. Also to get the lynch pins to fit into the clevis I had to take it to the grinder, you can use hitch pins instead, but they don't seem nearly as strong
