Welcome to Jeepz.com.
Results 1 to 5 of 5
    mls2157's Avatar
    mls2157 is offline Junior Member
    mls2157 is
    has no status.
    Jul 2009
    1
    2006 Liberty, Blower motor only works on high
    I have a 2006 Jeep Liberty and the blower motor only works on high????
    SteelHeadz's Avatar
    SteelHeadz is
    in need of gears for the front and rear axles. ;(
    Oct 2008
    Kerrville, TX
    5,841
    Type of Jeep
    CJ7/ AMC 360
    Re: 2006 Liberty, Blower motor only works on high
    Replace your blower motor resistor..It's located on the hvac housing on the passenger side behind the glove box..
    Low Ranger's Avatar
    Low Ranger is offline Member
    Low Ranger is
    has no status.
    Feb 2008
    Marysville, Ohio
    58
    Another bit of advice,, if you have the blower in your hand and there's an air compressor nearby, give it a good blast of air. Mine had alot of crap in it. If this yields a notable amount of stuff and you get it back in there run the thing on nothing other than high for a while. It'll get rid of anything that's left in there. The problem is that often we don't run the fan fast enough to get rid of dust that builds up and restricts cooling the motor. Also be sure the motor ventilation tube is tight fitting.
    jeepmaster's Avatar
    jeepmaster is offline Senior Member
    jeepmaster is
    has no status.
    Nov 2002
    Colorado
    1,240
    My Cherokee is doing something similar only mine is shrieking on anything but high and I get no air out of most of my vents even on high. How much is it to just replace the blower? I fear mine is toast. You should hear this sound!
    Summit County, Colorado - 96 XJ - Magnaflow exhaust, K & N filtercharger, H4 conversion, MT/R's on 767's, safari rack, hot blonde and an Australian Shepherd riding shotgun
    racefan52's Avatar
    racefan52 is offline Member
    racefan52 is
    has no status.
    Sep 2009
    45
    Type of Jeep
    Liberty
    mine did that and the dealer fixed it for free
  1. 2006 Jeep Liberty Total Engine Replacement
    By swigrus in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 01-22-2009, 02:54 PM
  2. heat/AC fan only works on high..??
    By Abutterfly in forum CJ YJ TJ and JK
    Last Post: 07-15-2008, 05:25 AM
  3. BLOWER SPEED!! i only have high
    By booe16 in forum General Chat
    Last Post: 04-24-2006, 10:57 PM
  4. "high output" blower motor
    By wm69 in forum General Chat
    Last Post: 10-23-2004, 08:20 AM
  5. heater only works on high setting
    By JeepGuyNY in forum CJ YJ TJ and JK
    Last Post: 02-09-2004, 01:56 PM
