    YuriSouder's Avatar
    YuriSouder is offline Senior Member
    Sep 2008
    Stillwater Mn
    167
    how do you water proof a jeep?
    I am going to get a safari snorkel and i was wondering what all the other stuff that i need to do in order to be able to sink the hood. I want to be able to drive this thing through streams as suck without having to worry.
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Re: how do you water proof a jeep?
    Don't forget to extend the axel , transmission, t.case vent tubes where the water can't reach it. try to install Dielectric grease on your electrical connectors to the sensors. it helps against water intrusions and corrosion in the long run. i'm sure i left a lot more info out from "waterproofing" your Rig but that's all that i can think of for now. oh and make sure you don't have a Vacuum leak or your for sure to find it.
    jonsolbe's Avatar
    jonsolbe is offline Senior Member
    Jan 2008
    Louisiana
    109
    Yikes! I had a friend whose really nice S10 4x4 got pulled back into a lake after trying to launch a boat which was too big (actually, it was one of your ten thousand!). It was submerged clear up the windows. After it dried out, the thing never ever ran right again. It was one electrical problem after another. Are you sure you don't just want to put the money in a GPS so you can find a bridge?
    Better get some good spark plug boots so your plugs don't ground out. If you kill the engine will water back up through the exhaust and into the engine?
    2005 Rubicon, 4inch Skyjacker, 750W inverter, on-board air front and rear, ARB front bumper w/ 2x55W Hella spots & 8kMM, rear swing away with 4x55W CAT work lights and custom jamboree rack with ammo cans, 2x5ga jerry cans, axe, shovel, pintle hitch, Sierra Off Road Trailer.
    TerryMason's Avatar
    TerryMason is offline Administrator
    Dec 1999
    Virginia Beach VA
    7,179
    One think you'll notice is that your axles / transmission / and transfer case will draw in water, as SteelHeadz mentioned. They have lines coming out of them to vent, and as you are running along, they will heat up and the air inside will expand. When you hit cold water, the air will constrict, as if your axle is breathing in. If your vent line is under water, instead of drawing in air, your axle will inhale water.
    Crazy4diesels's Avatar
    Crazy4diesels is offline Senior Member
    Oct 2008
    Boston
    393
    Do you have a distributor? If so, you'll need to seal that up pretty well... And, make sure you have NEW tight fitting spark plug wires. If these things leak you'll stall. The military M series vehicles (which were made to ford water) had highly specialized waterproof ignition systems. On these trucks you can not even see the distributor cap (it's inside a sealed "ignitor" unit). They had enclosed spark plugs and rubber packing glands at each end of the plug wires. You should change all fluids after swimming. Also, this is a manual tranny, right? Best of luck -John
    YuriSouder's Avatar
    Sep 2008
    Stillwater Mn
    167
    HOLY SH%$!!!!! thats allot more then i thought. Looks like i have some research to do. Keep me posted if you think of anymore helpful hints.
  7. #7
    Dan9's Avatar
    Dan9 is offline Senior Member
    Oct 2008
    Williamsville, NY
    117
    Just kind of tagging along on this, how come you asked if it was manual? i have an automatic, what does that mean? thanks
    Stock 2003 Wrangler X
    Future Plans:
    2-3" lift, 31-32" tires
  8. #8
    collestat's Avatar
    collestat is offline Junior Member
    Dec 2008
    8
    Just as an FYI, not sure if it's totally necessary here but Molex makes a great waterproof power connector. I don't honestly remember the name of it but if you happen to find it on their website (or call their tech support) you can then get FREE SAMPLES. This is true for any of their connectors and their system won't stop you from getting free samples until you place a number of orders inside of a month. I used to work there a few years ago so. You might have to sign up in their system which means you might get random emails every once in a blue moon but I think you can also order a free catalog if you're that interested...lol...just don't be surprised if a sales guy drops buy your garage or gives you a call sometime.
  9. #9
    SteelHeadz's Avatar
    Oct 2008
    Kerrville, TX
    6,087
    Quote Originally Posted by Dan9 View Post
    Either way it's going to have a vent tube. A manual transmission just have an extra vulnerable area for water intrusion, the shift boot on top of the trans .
  10. #10
    jps4jeep's Avatar
    jps4jeep is offline Moderator
    Dec 2002
    Boston
    6,657
    I perfer to stay out of water and out of mud. it will get into components that it shouldn't, create electrical gremlins, destroy parts, and personally, not much of a challange when it comes to driving.
    You can move vent tubes, add snorkles, seal this and that... water will probably get in.
    It used to be a jeep Thing,
    But all that stuff broke
    -Johnny-
  11. #11
    jmathews's Avatar
    jmathews is offline Junior Member
    Dec 2008
    8
    I can tell you from experience, stay outta the water its one headache after another
  12. #12
    jmathews's Avatar
    Dec 2008
    8
    Dan 9 i dont now why crazyfordiesels was asking if it was a auto tranny. But auto trannys have alot of more precision built parts that have to stay within certain tolerances. Like valve bodies they are in the lower unit of the tranny and the least little moisture or grit can cause them to stick witch in return will make your tranny not shift and act really funny. Not to mention the torque converter has fins in it that help aid in cooling and movement of the fluid, water and grit really takes a toll on them. I wouldnt recomend running in water that deep and if i did it surely wouldnt be with an automatic. Just my opinion
  13. #13
    YuriSouder's Avatar
    Sep 2008
    Stillwater Mn
    167
    its a 5 speed =)
  14. #14
    GOVT1911's Avatar
    GOVT1911 is offline Junior Member
    Apr 2007
    3
    I went a bit too deep with my 98 with auto last year. I apparently sucked a bit of water into the tranny, it wouldn't shift out of 2nd. I ended up flushing the tranny out a couple times and fixed'er right up! I'm not recommending you become a U-boat commander, but sometimes it's just too tempting! Do all you can to waterproof it and have fun. That's why we drive Jeeps for anyway, right?
    (BTW, I extended all my vent tubes and use dielectric grease on every electrical connection I can get to and besides the aformentioned problem, nothing major wrong YET!)
  15. #15
    Collin the Hen's Avatar
    Collin the Hen is offline Senior Member
    Apr 2008
    Indiana
    591
    You could saran-wrap your whole Jeep except for the wheels because that would be stupid. You can't really saran-wrap wheels and still drive... you know...
  16. #16
    Oct 2008
    Boston
    393
    Hey Dan9, Sorry I haven't got back to you on this... Manual vs Auto because most manuals have a vent that can easily be extended. Some water will probably still get in but, as long as you change the oil when you're done, you probably won't hurt it too much. I don't know about the "new" automatics out there ("new" as in after 1980) but the ones I've worked on had the vent right at the top of the oil pump inside the bell housing. There is no easy way to extend it. Water in an automatic will be very hard to get out (it will get into all the hyrdaulics) and will probably cause damage. Best of luck - John
  17. #17
    YuriSouder's Avatar
    Sep 2008
    Stillwater Mn
    167
    i think i am just going to get a ****ty samurai to drowned rather then my baby
  18. #18
    Itchee96's Avatar
    Itchee96 is offline Senior Member
    Dec 2007
    NC
    575
    Or you could just stay out of the water.
    Life is a trip, so give me another hit!
    SDMF
  19. #19
    xt master's Avatar
    xt master is offline Senior Member
    Nov 2008
    NE-PA
    1,472
    Buy a boat.They are made for water.Does seem like a lot of work to water proof the Jeep.
  1. Water Issue
    By Jackson04Jeep35s in forum CJ YJ TJ and JK
    Last Post: 07-07-2006, 05:56 AM
  2. Rooster Proof Stereo
    By redrooster in forum General Chat
    Last Post: 06-02-2006, 11:36 AM
  3. too much water
    By mailtruck in forum Cherokee, Commander, Wagoneer and Liberty
    Last Post: 07-08-2004, 01:56 PM
  4. 87 YJ - Water pump and fan
    By kerrja68 in forum CJ YJ TJ and JK
    Last Post: 05-07-2004, 04:02 AM
  5. Under Water now it is off and on? Help
    By dwelty in forum CJ YJ TJ and JK
    Last Post: 11-02-2003, 07:57 PM
