regarding what BH posted and the pic that is posted, is that just a mock up, or is this what you are actually measurements/ dimentions your running. I see a number of issues that you are going to have if this is going to be your setup.
1. the single spring your using for the 3/4 spring over extends the frame rail by what appears to be 5 inches, that spring is going to bend and possibly break very easily
2. you shackle angle looks near vertical if not negative, back into an obsticle, things are going to start to fold like a house made of cards. furthermore, since the lower spring does not appear to go as far back as the top, one good compression and the bottom spring will invert and the top spring again, will bend like a pretzal.
Oh shackles, assuming they are 3/16, I'd run them. I have had better luck with 3/4 suspensions with boomerang shackles and the top srping under the frame more with the bottom of the shackle at about 25 degrees positive
	 but ya all pics from now on say wut u want cause im tearin it down check out my new post in builds section im the first timer yj build
