Thanks, you might be able to get a winch that has cable on it instead of a strap, my local harbor freight didn't have any in stock.
And when you're ready to build it I can get you some measurements if you'd like
Sent from my Samsung Galaxy S3 using Jeepz
Building new dash
Installed with hinge at bottom for easy access
Getting ready for the Poison Spyder Ricochet Rock Sliders. The driver side looks clean, I didn't take off the passenger side. I've touched it up. It will be behind the sliders anyway.
Fixed the rattle I've been hearing for the last couple of years!
It turned out to be the air box rattling against the inner fender...
Changed out my upper and lower,control arms...got to love ohio everything was seized beyond belief on the axle end of the lca's.
Replaced the Bosch o2 sensor I put in a couple years ago with a NTK sensor
Added half a quart of oil. I would have washed it but tonight, one week after the official start of spring, we are supposed to get 3" to 6" of snow. I told my daughter to fill it up on her way to work tonight because she might be in 4wd all the way home in the morning.
Replaced my distributor cap rotor and throttle position sensor. Tomorrow to replace the crankshaft position sensor. Oh joys!
Finished wiring flat dash. Wired all gauges to factory harness. Always fun with volt meter and tracing wires.
Painted front grill and installed a Poison Spyder Brawler Lite bumper and skid plate on my 2012 JK 4 door!
